Home » Audio » Group Build » Need help with crossover design
Re: Need help with crossover design [message #67036 is a reply to message #67035] Wed, 13 April 2011 12:11 Go to previous messageGo to previous message
endrek is currently offline  endrek
I'm working on a X12 from Speakerplans.com
and i'm doubting of some things,
first of all, wich type of filter should i use if i want to make a pasive filter? Wich order? wich type?(with wich type i mean, bessel, butterworth,etc.... (my knowledge about electronics, isnt really good)) Sad
And the other question is, at what frequency should the filter separate the 2 woofers freq from the horn-driver???
possible answer:
1) You can ask the designer Smile
2) You can use an electronic crossover ,since it's a PA design it may be appropriate .
3) You can use the magic formulas that give you the values ,which may be adjusted later when listening and not finding them good enough.
but :
1) designer isn't avaible at his email Smile Smile
2) if i use a electronic XOVER (DSP right??) i will need to put two connectors to the X12 right? so i can separate the signal into MF and HF right? Or can i separate it with just one connector?? any advices please?
3)About the magic formulas, i'm starting to look/learn about it. Any good site to look? or cookbook?
the speakers are intended to be for high volume application, as loud as possible hehe.
My final goal is:
I'm building 2 bassreflex box with Fane Colossus 18 XB driver each. (40-250HZ aprox.)
And i'm building two X12. Thats why i'm thinking of a passive filter inside the X12 to sseparate MF and HF.
And I'm going to buy the correct amplifiers for them and a digital XOVER/COMP/LIM/EQ (DSP) for the all the PA
Any suggestions?? Or wich should be the better configuration???What i'm doing wrong? What can i improve?
pd: don't be cruel, i'm newbie, and i'm starting to learn everything Smile
thx for your help Smile
Really appreciate you can take me to the good/best goal Smile Smile
Previous Topic: Switchbox -- 6 in, 1 out
Next Topic: Two new valve based projects
Current Time: Sat Nov 07 12:12:27 CST 2026
