Re: Subwoofer AMP [message #66852 is a reply to message #66850] |
Sat, 02 April 2011 19:23 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Messages: 18753 Registered: January 2001
Certainly, that will work just fine. Tap into the preamp signal going to the amp for your mains, and run it to a sub crossover. I've tried several crossovers, and had good results, some better than others. Ironically, the one I like best for multisubs is this little thing:
It's not the prettiest thing to look at, and rates a zero in "cool factor". It's probably not audiophile approved. But it's easy to sneak it up to really good quality levels with the Burr Brown and capacitor upgrade mods. It has a nice gentle 12dB/octave slope, perfect for blending. Crossover points are selectable, and they work out nicely for flanking subs (selecting 90Hz or 180Hz) or for more distant subs (selecting 50Hz low-pass). Once it is setup, you can just leave it on so there's really no reason it shouldn't be out of sight and out of mind.
Re: Subwoofer AMP [message #66861 is a reply to message #66850] |
Sat, 02 April 2011 23:55 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Adveser
Messages: 434 Registered: July 2009 Location: USA
Illuminati (1st Degree) |
Quote: | It's probably not audiophile approved.
But what is? 101% is impossible, so those guys will never be happy.
You are going to need roughly double the wattage for the sub amp as the main amp too.
http://adveser.webs.com/
