I also got the H290's today. I just tried mounting them to my 2426H but had a hard time to reach the skulls of the three screws to attach the driver. It is very tight between the horn and the screws. My screw skulls are 11mm wide, is this bigger than normal? What kind of tool do you use?
Wayne Parham Messages: 19103 Registered: January 2001
That is a tight fit when you use the three-hole mounts instead of the two. When using the two hole mounts, it's easy. But the three hole mounts are right up close to the body. I use an open end socket wrench to tighten these bolts.
