Home » Sponsored » Pi Speakers » Driver selections (4pi)
Re: Driver selections [message #66830 is a reply to message #66813] Fri, 01 April 2011 14:16 Go to previous messageGo to next message
JakobR is currently offline  JakobR
I recieved the plans, thank you very much.
I also got the H290's today. I just tried mounting them to my 2426H but had a hard time to reach the skulls of the three screws to attach the driver. It is very tight between the horn and the screws. My screw skulls are 11mm wide, is this bigger than normal? What kind of tool do you use?
Kind regards,
Jakob
Re: Driver selections [message #66835 is a reply to message #66830] Fri, 01 April 2011 15:13 Go to previous message
That is a tight fit when you use the three-hole mounts instead of the two. When using the two hole mounts, it's easy. But the three hole mounts are right up close to the body. I use an open end socket wrench to tighten these bolts.
Previous Topic: Wayne, which speaker for PA tops?
Next Topic: One pi plans please
Current Time: Sun Oct 25 13:16:34 CDT 2026
