Home » Sponsored » Pi Speakers » Tweeter change revisited
Re: Tweeter change revisited [message #66665 is a reply to message #66624] Tue, 15 March 2011 16:07 Go to previous messageGo to previous message
RDLewis is currently offline  RDLewis
Good to see your attempt. Shame it was not the Neo3, its not quite as easy here, as nobody stocks the latter here in the UK. So I may have to pluck up my courage and go for it !
Where bass drivers are concerned, the Alpha 10, looks a better driver for the reasons Wayne has made. Also if you look on the "Prodance" website, you will find both drivers tested. The "10" looks quite a bit better, with the specteral decay, much cleaner, less break up. From what I have seen the 10 has a response at least as good as many more expensive HiFi drivers. It may loose out at the bass end but gains in sensitivity. All a compromise
Previous Topic: One pi plans please
Next Topic: 4 pi request
Current Time: Thu Nov 05 22:50:42 CST 2026
