Home » Sponsored » Pi Speakers » Four Pi R3 Mounting
Four Pi R3 Mounting [message #66533] Sun, 06 March 2011 13:23 Go to next message
pizzachef is currently offline  pizzachef
Wayne, I am coming into the home stretch on three 4 pis. I am mounting the crossover boards to the bottom of the speaker using a shower pan liner as damping. However, I am worried about how hot the separate R3 (8 ohm, 100watt) resistor gets -- it must be separate and have heat sinks for a reason. I was going to mount it vertically to the side of the speaker with no gasket direct to the mdf. I was worried the gasket might make the heat sink on the back infective. Does this sound OK?
Re: Four Pi R3 Mounting [message #66546 is a reply to message #66533] Sun, 06 March 2011 22:08 Go to previous message
Don't worry, you can mount the resistor directly to the bottom of the cabinet with or without a gasket underneath. There's plenty of heat dissipation - It was designed to be mounted this way.
Previous Topic: 2226j (16 ohm) usable?
Next Topic: Another 4pi question
Current Time: Sat Nov 28 19:18:22 CST 2026
