Home » Sponsored » Pi Speakers » 2226j (16 ohm) usable? (question about 4pi)
Re: 2226j (16 ohm) usable? [message #66532 is a reply to message #66369] Sun, 06 March 2011 13:21 Go to previous messageGo to previous message
If I may say so Wayne...
If you can get the drivers cheap, why not just install two drivers in parallel? Or would this cause too many problems with the design of the speaker box?
While we are on the subject, does more drivers reduce the modes inside the box ala, multisub?
I looked around last night to see if there was an electrical solution and essentially there is no way to dissipate the heat with resistors and it's flat resistance to all frequencies makes them useless.
Previous Topic: Tweeter Change (again !)
Next Topic: Four Pi R3 Mounting
Current Time: Sat Nov 28 19:05:16 CST 2026
