Home » Sponsored » Pi Speakers » Where's the best tweeter position? Aesthetically, too?
Re: Where's the best tweeter position? Aesthetically, too? [message #66225 is a reply to message #66219] Sun, 20 February 2011 09:38 Go to previous messageGo to previous message
I would put the tweeter straight above the woofer, if possible. Maybe if you want to shift to the left or the right for baffle step reasons, do both woofer and tweeter so they're still vertically aligned. That way the nulls are directly above and below, rather than at an oblique angle.
I'm not sure it's terribly important if the nulls are slightly oblique, but the further off it gets, I think it becomes more of a problem. Once you get past 30° or so, it would be hard to keep the nulls out of the listening area. So I would try to reduce the offset, and not even do it unless baffle space dictated it, i.e., just can't fit the parts on the baffle any other way.
Previous Topic: Request plans and Klipschorn question
Next Topic: Pi 4 Owners: How Big is your "space"
Current Time: Thu Nov 05 23:50:12 CST 2026
