Home » Audio » Silicon Valley » Amps for Home
Re: Amps for Home [message #65978 is a reply to message #65972] Fri, 04 February 2011 12:37 Go to previous messageGo to previous message
Lancelot wrote on Thu, 03 February 2011 22:00
What do you mean by flatter response? How can I gauge the speaker whether it will produce a flat response or not?
It is truly amazing how a very small and light thing can produce a very loud sound.
Well the speaker doesn't really output a flatter signal, it produces a more compressed signal which your ear will perceive as flatter at the end of the day because quieter sounds will be closer to the louder sounds in amplitude. This is why guitarists are picky about wattage, they want the speaker cones to start breaking up at a certain level. You may or may not want to do that on your home stereo, so that should determine how much wattage you are pumping into the speakers. You would really have to be careful too because tweeters will blow if you are not attenuating the treble closer to it's limitations. And naturally, just because a speaker can handle a certain power rating does not mean you can go nuts by pumping in a 100watt signal at 20hz...that is going to destroy the speaker too despite it being able to handle 240watts, for this example.
Previous Topic: AMP cracking and popping
Next Topic: Cleaning up Amps
Current Time: Fri Nov 13 02:46:21 CST 2026
