Home » Sponsored » Pi Speakers » [Pi2 Tower] Insulation on braces
Re: [Pi2 Tower] Insulation on braces [message #65618 is a reply to message #65598] Fri, 07 January 2011 09:16 Go to previous messageGo to previous message
I use white glue. Works perfectly. You might think it would tear away, but I've had speakers out there like that for decades, some that have been moved a lot. So it works well.
Cut a sheet of insulation to size, take the vapor barrier backing off, run a long beads all around on the surface of the wood you want to attach the insulation to. Then just press it into place.
At one time I tacked the insulation in with staples. It's fast and easy. But occasionally the staples come out over time, and you'll find them stuck to a magnet or bouncing around inside, even worse. That caused me to rethink the staples idea, and I never do it that way anymore. It's easier to tack in the insulation with a staple gun, but I don't think it's as good as white glue.
Previous Topic: Help with tweeter to woofer distance please
Next Topic: 2 pi tower baffle
Current Time: Fri Nov 06 00:06:37 CST 2026
