Home » Audio » Speaker » Magnepan 1.7 Crossover
Re: Magnepan 1.7 Crossover [message #65499 is a reply to message #65498] Sat, 01 January 2011 14:50 Go to previous message
Wayne Parham wrote on Sat, 01 January 2011 13:11
OK, I see, it isn't electrostatic. It's an electromagnetic ribbon. Cool, makes crossover work easy.
For a product that naturally has smooth and extended highs it is a mystery how they are getting these things to sound glassy or shrill as the review suggests they are.
I mean they would have to be really distorting the lower order speakers with the crossover configuration sending HF info to them or possibly exceeding the limitations of the tweeter in this design. I don't what's up without hearing them, but the characteristics described in the review don't match my perception of how the equipment SHOULD work. He says it sounds "wrong" so maybe he is right.
Previous Topic: Subwoofers
Next Topic: Can you Patch the Hole in a Speaker?
Current Time: Fri Nov 13 09:35:25 CST 2026
