Home » Audio » Home Theater » Small system for a narrow room
Small system for a narrow room [message #64954] Sun, 28 November 2010 08:43 Go to next message
Rap14 is currently offline  Rap14
We want to turn our basement into a theater type room. It's a finished basement (50%) of it. We have about half the room to use - there is a wall that separates the basement.
I'm looking for a good small home theater for a smaller area. Any suggestions?
Bee Bop Bee Bop!
Re: Small system for a narrow room [message #64963 is a reply to message #64954] Sun, 28 November 2010 13:25 Go to previous messageGo to next message
NoDirections is currently offline  NoDirections
What is the wall that is going to be separating the entertainment area made of? Can you mount stuff on it? Is the room too narrow to put the TV on one of the long walls? I think we need a better idea of your ideas.
Re: Small system for a narrow room [message #64965 is a reply to message #64954] Sun, 28 November 2010 13:43 Go to previous messageGo to next message
I think that we are better off putting the TV on the other wall, the wall that separates the room would not work - it splits the room so there is not a lot of room to put the couch or chairs in that direction. I'm thinking a Big screen (flat) TV on the far wall and the seating against the other far wall. I would say the room is 12 feet wide and 50 feet long (just an estimate). The walls are concrete (except the wall that separates the room in 2).
Bee Bop Bee Bop!
Re: Small system for a narrow room [message #64971 is a reply to message #64954] Sun, 28 November 2010 16:16 Go to previous messageGo to next message
These look like a great deal:
http://www.amazon.com/Sony-SS-B3000-Bookshelf-Speakers-8-Inch/dp/B000OG6I6A/ref=sr_1_1?ie=UTF8&qid=1290982511&sr=8-1
Re: Small system for a narrow room [message #64989 is a reply to message #64954] Mon, 29 November 2010 18:50 Go to previous messageGo to next message
It does look like a great deal for speakers, they look a bit too big for our room though. Where is the rest of the home theater?
I'm kind of leery buying online, is that odd?
Bee Bop Bee Bop!
Re: Small system for a narrow room [message #65003 is a reply to message #64989] Tue, 30 November 2010 08:45 Go to previous messageGo to next message
It's on the same page:
Frequently Bought Together
Sony SS-B3000 Bookshelf Speakers with 8-Inch Woofer (Pair, Black) + Sony SS-CN5000 Dual 5.25" Center Channel Speaker (each, black) + Sony SS-B1000 5 1/8-Inch Bookshelf Speakers (Pair)
Price For All Three: $197.93
* This item: Sony SS-B3000 Bookshelf Speakers with 8-Inch Woofer (Pair, Black) $76.97
* Sony SS-CN5000 Dual 5.25" Center Channel Speaker (each, black) $69.99
* Sony SS-B1000 5 1/8-Inch Bookshelf Speakers (Pair) by Sony $50.97
Re: Small system for a narrow room [message #65012 is a reply to message #64954] Tue, 30 November 2010 13:17 Go to previous message
XGamer is currently offline  XGamer
Don't be shy about buying online if it's from a brand with a good reputation; honestly, I've gotten so many better deals online that I never would have gotten otherwise.
Previous Topic: Cassette players?
Next Topic: Home Theatre Recommendations
Current Time: Fri Oct 16 04:51:21 CDT 2026
