Home » Sponsored » Pi Speakers » Pi4 New Owner
Re: Pi4 New Owner [message #64616 is a reply to message #64615] Mon, 08 November 2010 14:50 Go to previous messageGo to previous message
Silicon breaks down very fast with certain solvents. Brake cleaner, for example, will turn silicon to runny goo in seconds. Whether or not you can get the solvent to the silicon without getting it on the finish is a different matter.
I might be inclined to dribble a tiny bit of it on the horn from the inside of the cabinet, on the back of the horn, so that it contacted the silicon without getting close to the finish. If you can do that, the horn will probably break free pretty easily. But do heed my warning about getting any on the finish. Some stuff is more resilient than others, like polyurethane verses lacquer or shellac. But pretty much nothing lives long when in contact with brake cleaner.
Previous Topic: Pi2 and woofer directivity
Next Topic: 2Pi questions
Current Time: Fri Oct 23 12:11:06 CDT 2026
