Home » Sponsored » Pi Speakers » A Possible 2.5 PI?
A Possible 2.5 PI? [message #64552] Mon, 01 November 2010 00:53 Go to next message
I've got a problem; my living room is small. I recently built a pair of 1 PI speakers. I love them. I put them in my living room to replace a popular mini-tower horn loaded system. They are physically too wide for the room. Where the original speakers fit nicely, the PI's don't. I can't leave them out in the room. The 1 PI's are relegated to my garage shop where they are playing nicely. So I need to build a 12-13 inch wide tower pair for my room. So... I thought this might work. My first idea is to build the 2 PI's sideways so they fit the space. Idea number two is to take this a step further and build the same 2 PI's, but horn load the tweeters like 3& 4 PI's. I already have a pair of the Eminence horns and drivers as Wayne uses in his higher end designs. (My third idea is to throw out my TV monitor and cabinet to gain more space and risk divorce.) My concern is that the narrow woofer baffle may become too narrow and need baffle step correction and I hope to avoid that. Help please, advice needed.
Steve
two π tower vs. eight π [message #64553 is a reply to message #64552] Mon, 01 November 2010 09:35 Go to previous messageGo to next message
Some people have built the towers "sideways" and have liked the results. I would suggest doing that instead of the smaller bookshelf model if they're going to be used as mains and not surrounds, especially if you won't be using subs.
About baffle step compensation, I'd suggest it might be better to incorporate subs than to try and push the mains down deeper. That's one way to deal with reduced bass output and it has the added benefit of helping smooth the modal region too.
As for using a compression driver with a 10" midwoofer, that's what the eight π speaker is. It uses a midhorn to control directivity because the pattern without a horn is too wide. A larger midwoofer driver narrows directivity at lower frequency and is a good match for the tweeter horn but the smaller midwoofer needs extra pattern control, so a midhorn is used.
Of course, neither the two π and two π tower speakers are CD so I suppose an argument could be made that adding a horn doesn't necessitate matching directivity. But to me, that's the main advantage of using the horn in the first place. We're looking for controlled directivity. So if you want CD, use horns but if it isn't a requirement, stick with the dome tweeter in the stock two π design. That's my advice.
Re: two π tower vs. eight π [message #64554 is a reply to message #64553] Mon, 01 November 2010 10:34 Go to previous messageGo to next message
Wayne,
Thanks for the quick reply. To be honest, I completely forgot about the 8 PI. It's also too wide for my room, but I get the idea. I agree that directivity matching is important. I would prefer CD, but it doesn't seem possible for my room. (Heck, then I'd be considering 4 PI because I can't place a corner horn anywhere.) My next house will be much more audio friendly.
Unless I can make a few changes in the room itself, "sideways" 2 PI may be the answer. I could have massaged the dimensions of a pair of 1 PI as I do have subs, but a tower is preferred as I don't like speaker stands. Out of curiosity, what is the f3 for your 2 & 8 PI speakers?
Steve
Re: two π tower vs. eight π [message #64555 is a reply to message #64554] Mon, 01 November 2010 14:47 Go to previous messageGo to next message
The f3 of both loudspeakers is about 40Hz. But the eight π is pretty wide because of the midhorn. It does provide CD, but from what you've said it isn't an option because of size constraints.
I think the two π tower is the natural choice for you. On axis, and slightly off axis (like +/- 20° or so), it sounds really nice. The soft dome tweeter is a good match and the system sounds great.
Here's the response curve and impedance of the two π tower:
http://www.pispeakers.com/Measurements/twoPi_tower_response.jpg
two π tower response
(Click on image to zoom in)
http://www.pispeakers.com/Measurements/twoPi_tower_impedance.jpg
two π tower impedance
Re: two π tower vs. eight π [message #64564 is a reply to message #64555] Tue, 02 November 2010 10:51 Go to previous message
Wayne,
I agree. Unless I can convince my much better half that she really doesn't need her cabinets. Then 4PI here I come. Rolling Eyes Seriously, the 2 PI "sideways" is a really good design that a lot of audiophiles would enjoy. When I get more space, I'm sure they will make great surrounds or a nice bedroom system.
Steve
Previous Topic: Karlson perfect pitch ?
Next Topic: horn for 2 inch driver
Current Time: Fri Nov 13 12:48:14 CST 2026
