Home » Audio » Source » Recording Music from Cassette Tapes
Recording Music from Cassette Tapes [message #64410] Thu, 21 October 2010 06:52 Go to next message
3dfreak is currently offline  3dfreak
I could download a lot of music I like from Limewire these days. But some are simply hard to find, like "It's About Time" and "I Want to Live' by John Denver. I know it's possible to just play the old cassettes I got and record them as WAV file straight into the computer. My problem is that the volume from the file is lower than the original. Any idea where I may need to fix this problem? Or is there a better way?
Re: Recording Music from Cassette Tapes [message #64418 is a reply to message #64410] Thu, 21 October 2010 09:22 Go to previous messageGo to next message
What software are you using to record the cassette? If you just use Microsoft Sound Recorder, for instance, you can't do as much. Maybe try using Audacity (it's free!) so you can increase the volume. Good luck!
Re: Recording Music from Cassette Tapes [message #64419 is a reply to message #64410] Thu, 21 October 2010 09:46 Go to previous messageGo to next message
mp3gain @ 96db
Freeware:
http://mp3gain.sourceforge.net/
Re: Recording Music from Cassette Tapes [message #64424 is a reply to message #64410] Thu, 21 October 2010 14:42 Go to previous messageGo to next message
Wolfgang is currently offline  Wolfgang
There's an equipment that lets you transfer from audio to cd. I had my Italian lessons audio cassettes turned to cd in Baguio, Philippines.
I also saw a gadget where you can play your cassette and plug it in cd player but it was in Thailand. I just can't recall how exactly they call it. Confused
Re: Recording Music from Cassette Tapes [message #64431 is a reply to message #64424] Fri, 22 October 2010 07:30 Go to previous message
I used a cassette player with a line out jack. Then, using an RCA-to-PL connector connected to the line out jack, I fed the sound from the player to the microphone jack of the computer. Yes, I used Microsoft sound recorder.
I'll check the softwares you indicated and keep you posted. Thanks!
Previous Topic: Legally download music to burn to CDs?
Next Topic: NOT fair - amp issue
Current Time: Sat Oct 17 08:32:08 CDT 2026
