Home » Sponsored » Pi Speakers » Just bought some JBL 3677...? about the CD and horn
Re: Just bought some JBL 3677...? about the CD and horn [message #64211 is a reply to message #64175] Thu, 07 October 2010 07:53 Go to previous messageGo to previous message
CDY2179 is currently offline  CDY2179
Thank's for takng the time to explain that Wayne. Some of that I thought of, some I didn't. The H290s is actually very close to the same size as the 2373 horn within .5" in all measurements. The Selenium HC23-25 is quite different. So if the H290 performs well I should be OK just swapping it out...Right? The depth is about the same so I shouldn't have any delay problems and when I build new boxes I just need to maintain the CD to woofer distance.
Does it sound like I'll be OK?
Also last night I put the JBL CDs back in and it has a much stronger sound to it than the Seleniums do. It sounds a lot better with vocals near the Xover point as it seems to blend with the JBL 15s much better. I EQed the treble up also which did help the top end.
Previous Topic: NOS 1 PI's
Next Topic: 4pi
Current Time: Fri Nov 13 01:00:44 CST 2026
