Home » Sponsored » Pi Speakers » Midrange Horn
icon14.gif  MID HORN FLAT PACK [message #63977 is a reply to message #44366] Thu, 02 September 2010 12:23 Go to previous messageGo to previous message
biglaz is currently offline  biglaz
Wayne,
I received the (2) Mid Horn flat packs from UPS yesterday. Opened them this AM. Extremely well packed with your expanding foam on the corners. (You must like the expanding foam because I remember you used it to fill the cavity of I believe the 10Pi.) Anyway, no damage.
For any forum member thinking about this flat pack do not hesitate. It took only about 30 minutes to assemble both horns, no drivers yet. All the dowels lined up and if you follow the number code you can not mess up. Can't wait to mount the drivers and give them a listen.
FYI. I attempted to build this horn twice. Even though I ended up with reasonable facsimiles they were just not right.
Thanks,
Robert
PS. Need Pi emblems to stick on the horns.
Previous Topic: How good is the 1Pi? Pretty good, I think.
Next Topic: I covet the 7Pi Plans...
Current Time: Mon Oct 19 15:43:43 CDT 2026
