Home » Sponsored » Pi Speakers » 8 PI QUESTION
8 PI QUESTION [message #63909] Mon, 23 August 2010 08:06 Go to next message
vmps_VOON is currently offline  vmps_VOON
hi wayne
other than a compression driver for the top ? can i use any other tweeter? and what is the requirement ?
vmps
Re: 8 PI QUESTION [message #63911 is a reply to message #63909] Mon, 23 August 2010 09:42 Go to previous message
It was designed for a compression driver, and I think that's the best kind of tweeter to use for a matched-directivity two-way loudspeaker. It gives you everything you need in terms of suitability for horn loading, SPL and response. Everything sort of comes together, the crossover point requirements, directivity, SPL (allowing mass-rolloff compensation), etc.
If you want a simpler loudspeaker that uses a dome tweeter, for example, then I suggest maybe going with a two π loudspeaker instead.
Previous Topic: 2-Pi Tower floorbounce
Next Topic: Active tube crossover
Current Time: Sat Nov 07 03:36:18 CST 2026
