Home » Audio » Pro Sound » Advice building bass cab
Re: Advice building bass cab [message #63888 is a reply to message #63883] Fri, 20 August 2010 17:18 Go to previous message
notben is currently offline  notben
Thank you Wayne.
That was the only other thing I could think the Vtotal could be, but I wasn't sure.
I did fine a cool little BASIC compiler that you can run online: http://www.calormen.com/Applesoft/
Your code worked and I am able to calculate the FR.
Although, Eminence specifies two ports for their cab design.
Figuring out the standing waves is over my pay grade. Looking at other 1x12 ported bass cabs, I see some with ports stacked on the the side with the driver off set, so I think I will just try that alignment.
Thanks.
Previous Topic: Teens Electric Guitar
Next Topic: Normalizing
Current Time: Mon Nov 16 08:00:09 CST 2026
