Home » Audio » Craftsmen » Effect of Length
Re: Effect of Length [message #63614 is a reply to message #63609] Mon, 02 August 2010 02:34 Go to previous messageGo to previous message
Lancelot is currently offline  Lancelot
Keith Larson wrote on Sun, 01 August 2010 22:57
Incidentally when something sounds bad, what I usually find to be most problematic are bad connections, oxidation and corrosion. Basically this is loose screws, oxidized wire and incompatible metal contacts.
Does this mean that a wire subjected to environmental variables like rain or wind can change the volume or sound quality that run through it? I thought the cords are protected from these elements.
Previous Topic: Nostalgic DIYers
Next Topic: I know you hate t-nuts so
Current Time: Fri Oct 16 14:52:30 CDT 2026
