Home » Sponsored » Pi Speakers » Pi 4.5 possible? (Pi4 with two JBL 2226H's)
Re: Pi 4.5 possible? [message #63434 is a reply to message #63433] Sun, 18 July 2010 15:26 Go to previous messageGo to previous message
Infrasonic is currently offline  Infrasonic
No problems regarding load on the amp. Right now the amps in my AVR are quite robust and powerful for it's class. It's good for a 3ohm load if required. I may even upgrade to a pro amp down the road so loads down to 2ohm pose no real issues at the moment.
So if I read your reply correctly I can hook both woofers to the lowend output of your crossover but with a inductor in series between the bottom woofer and the output of the crossover? Is that right? Or do I just hook the midwoofer to the network and have just the inductor on the bottom woofer?
Sorry, just want to be sure. Wink
Thanks a ton!
Previous Topic: 4Pi Plan Request
Next Topic: Kilomax-18
Current Time: Thu Nov 26 03:59:45 CST 2026
