Wayne Parham Messages: 19102 Registered: January 2001
Do you have any spam blockers running? ART's email server is different than the π Speakers server, so you could be blocking one while receiving the other. I've just sent it again, so check now. If it's still not there, I'll resend to another address.
I was wondering if it's possible to substitute different horns into your design? I've got a set of the QSC HPR-152i horns that accept the same B&C DE250 compression driver. Can I swap this horn in place of the one specified in the plans?
Here is a picture of the horn (hope penn doesn't mind me borrowing his image ):
You really can't just swap in different horns, in most cases, as they're going to fundamentally change the radiation pattern of the loudspeaker, even if the horns being considered generate the same advertised pattern. If two horns have different dimensions, they'll probably impart a different acoustic phase if for no other reason than the sound sources are in different positions.
