Home » Sponsored » Pi Speakers » 4pi with altec 807?
Re: 4pi with altec 807? [message #63167 is a reply to message #63163] Tue, 15 June 2010 01:22 Go to previous messageGo to previous message
geezer is currently offline  geezer
Of course your right, its a 811 horn I meant. I might want to try a build with these components inspite the big crossover issues. I have the Minidsp which is an active crossover that I can fool around with, and if the results don´t end up satisfing I could always get back to the orginal 4pi design.
As you said it would be a totally different speaker but I wonder if you have any particular design advise? Considering your experience and knowledge about the jbl 2226 woofer.
My plan was to stick to the same tuning-frequency, port dimension and volume as the 4pi.
Thank you for the fast reply!
/Anders
oh and do you have 4pi-plans?
Regards
Previous Topic: 2pi crossover question and opinion for near-field monitoring
Next Topic: three π speakers at LSAF 2010
Current Time: Sat Oct 31 17:11:55 CDT 2026
