Home » Sponsored » Pi Speakers » 3Pi or 4Pi better than modded Klipsch Quartet?
Re: 3Pi or 4Pi? [message #63106 is a reply to message #63103] Wed, 09 June 2010 11:06 Go to previous message
Yes, the four π speaker is 3dB louder than the three π, given the same input. That can make a difference for flea-power SET amp owners.
All my tube amps are around ~10 watts and with this much power, either speaker is fine. You can tell the difference, but the three π speaker just needs a little more twist of the volume knob, not much. It is plenty loud, even for home theater.
If you have a lot less power than that, say under ~2.5 watts, then the extra sensitivity of the four π speaker probably becomes more of a consideration. Once you get down to the little 1 watters, they're not really what I'd consider a power amp, more like a headphone amp. At that ultra-low power level, neither speaker will get above a polite conversation level.
Previous Topic: P Audio 2226 copy- opinions?
Next Topic: Heresy Box for 3Pi
Current Time: Fri Nov 06 06:31:15 CST 2026
