Home » Audio » Thermionic Emissions » Audio Note power transformer
Re: Audio Note power transformer [message #63070 is a reply to message #63015] Sat, 05 June 2010 13:01 Go to previous messageGo to next message
Frihed89 is currently offline  Frihed89
It's possible. The old AN caps were made by Jensen and had leakage problems. The new AN copper foil caps are no longer made by Jensen. And even Jensen has discontinued the old production model. Their factory is not too far away, but I still prefer AN.
Re: Audio Note power transformer [message #63074 is a reply to message #63070] Sat, 05 June 2010 23:29 Go to previous messageGo to next message
I've used dozens of those old-model Jensen/Audio Note PIO caps, and have been fortunate that (to my knowledge) not one has ever failed in service. Of course, I observe some extra precautions when using PIO caps. I avoid using them where very high internal chassis temperatures are present. I also use carbon composition grid stopper resistors with them, as the composition media is a poor conductor of heat, and helps isolate them from heat conducted from the power tube socket.
Many PIO caps have poor thermal stability; when cold their DC resistance may be hundreds of megohms, but it plummets as they become hot. I once saw a Chinese-made PIO totally lose it just a few minutes after turning the amp on, due to heat conducted into it through its leads. You could see the results of the DC leakage as it increased; the power tube began to glow in a tiny spot or two, and then eventually hotplated all over. I replaced it with a Jensen, and about 5 years of daily use later, the amp is still doing well.
Thermionic
Re: Audio Note power transformer [message #63077 is a reply to message #63074] Sun, 06 June 2010 09:05 Go to previous message
The capacitors that failed in my amp were the new production Audio Note caps. Not to take away any of the good information on the Jensens or on paper in oil caps in general. Just wanted to clarify.
Previous Topic: Why SE in SET amps?
Next Topic: Opinions please-New EL34, 6CA7, KT88 and 6550
Current Time: Tue Nov 03 20:49:07 CST 2026
