Home » Audio » Thermionic Emissions » Audio Note power transformer
Re: Update: Audio Note power transformer [message #63004 is a reply to message #11428] Tue, 01 June 2010 03:50 Go to previous messageGo to previous message
Frihed89 is currently offline  Frihed89
I see you traced this problem back to a resistor. I would add that the new AN copper foil caps make very good coupling caps in a wide range of equipment, but are pricey, although not like the Vcaps or AN silver foils. The new AN caps are no longer made by Jensen. However, Jensens new caps no longer leak and specs appear tighter. If you order AN caps, try and get them matched.
Previous Topic: Why SE in SET amps?
Next Topic: Opinions please-New EL34, 6CA7, KT88 and 6550
Current Time: Fri Nov 13 21:36:51 CST 2026
