Audio
Blocking Sound Out of a Room
Re: Blocking Sound Out of a Room
message #62945
is a reply to
message #62521
Fri, 28 May 2010 21:43
Mavare
February 2010
You could also try the foam insulation sheets. You could use it while you are on the job and then take it down so you could see out of the window. A sheet of it doesn't cost much at a DIY store and you should be able to cut it to fit the window.
Message index
By:
CountryFried
on Wed, 05 May 2010 13:08
By:
on Wed, 05 May 2010 13:33
By:
Mavare
on Fri, 28 May 2010 21:43
By:
DaBase
on Wed, 02 June 2010 17:05
By:
musiclover
on Tue, 08 June 2010 04:19
By:
JiminyCricket
on Wed, 28 July 2010 00:26
By:
candoon
on Wed, 28 July 2010 12:42
studio speakers
Possible move
Thu Oct 01 15:20:42 CDT 2026
