Home » Audio » Radio » zenith transoceanic b600, 6A40 chassis removal (Chassis removal)
zenith transoceanic b600, 6A40 chassis removal [message #62725] Sun, 16 May 2010 20:51 Go to next message
nordlander is currently offline  nordlander
I hope there isnt another thread for this. I searched and found nada.
I just picked up a 98% condition TO b600. Cover is dirty but good. No nests inside. Wiring looks great. Wave magnet line is fine.
For $15
Kicker is...dont work.
tuner is stuck.
Power tube lights but thats it.
I need to remove the chassis to check for caps underneath.
I'm obviously too stupid to figure it out and I'm pretty mechanically inclined.
Any hints?
Thanks for your time!
Re: zenith transoceanic b600, 6A40 chassis removal [message #62756 is a reply to message #62725] Sun, 16 May 2010 23:32 Go to previous messageGo to next message
Oh, man, did you score! TransOceanics always go for at least a hundred bucks, in good shape over $200, sometimes more.
These are pretty easy to work on. Open up the back and you'll see the chassis. There are screws on the bottom, and after they're out, the chassis slides right out. Be careful of the antenna connection though.
I agree with you about the caps. Replace 'em as a matter of good measure. Then check all the tubes. I usually buy a set for every radio I have even if it works, just for a backup set. In your case, you may need to replace a tube or two to get it working.
Re: zenith transoceanic b600, 6A40 chassis removal [message #62758 is a reply to message #62756] Mon, 17 May 2010 00:53 Go to previous messageGo to next message
Thanks for the quick reply!
Do I need to remove the volume and tuner knobs first? If so, whats the procedure?
Re: zenith transoceanic b600, 6A40 chassis removal [message #62762 is a reply to message #62758] Mon, 17 May 2010 09:08 Go to previous messageGo to next message
Yes, remove the knobs. They pull straight off.
Re: zenith transoceanic b600, 6A40 chassis removal [message #62765 is a reply to message #62762] Mon, 17 May 2010 22:47 Go to previous messageGo to next message
Thx!
I did just that.
I got some tuner cleaner from Radio Shack. they suggested i hit it with wd40, work it a bit, then clean it.
sucker rolls sweet now. still dont work though.
Pulled the chassis to look for bulged caps. they all looked good.
Can I check the caps while they're still connected? These things look like giant resisters! I think some are.
I've included a couple of pix.
The striped things I think are caps. ?
Purple things? No idea.
The orange thing. selinium diode?
Re: zenith transoceanic b600, 6A40 chassis removal [message #62766 is a reply to message #62762] Mon, 17 May 2010 22:48 Go to previous messageGo to next message
BTW,
33rd.
Are you a "travelin man"?
Re: zenith transoceanic b600, 6A40 chassis removal [message #62767 is a reply to message #62765] Mon, 17 May 2010 23:29 Go to previous message
Personally, I'd replace all the electrolytic caps with polypropelene caps. I think it's safe to assume they're weak beyond usability. Don't replace resistors unless you know they're bad (which I doubt). Selenium rectifiers are high failure items, although most radios I have with them, they're fine.
Previous Topic: Anode
Next Topic: Westinghouse n202
Current Time: Sun Oct 18 20:52:06 CDT 2026
