The small additional volume doesn't make a significant change when removing the horn. So don't reduce internal volume to compensate. Essentially, just flip the box over so the woofer is near the top rather than the bottom. When you add the π wood tweeter horn, the mouth should be flush with the baffle. That's where it goes for proper alignment, same as the H290.
