Home » Audio » Radio » Any advice on long wire antenna
Any advice on long wire antenna [message #62361] Sat, 17 April 2010 21:26 Go to next message
capbuster is currently offline  capbuster
This might be in wrong post. I tried a long wire at 50foot . did not work well. Any advice on best way to run one. Ihave a old philco 11 tube . More tubes the higher but that would probaly be 160 foot. Any way to construct a antenna not going so high ? Rolling Eyes
Thanks Capbuster. Smile
Re: Any advice on long wire antenna [message #62362 is a reply to message #62361] Sat, 17 April 2010 22:56 Go to previous messageGo to next message
Long wire antennas are pretty simple critters, really. The longer the better, the higher the better, the further away from objects (particularly metal) the better. You can also use a tuned antenna (of specific length) but if you're tuning shortwave, sometimes you really want a broadband general purpose longwire.
There are a lot of good links on the internet, some some searches are in order. Here are a few good ones:
Re: Any advice on long wire antenna [message #62366 is a reply to message #62362] Sun, 18 April 2010 16:05 Go to previous message
Thanks alot will check these out Capbuster Razz
Previous Topic: philco model 111
Next Topic: Anode
Current Time: Wed Oct 14 09:08:28 CDT 2026
