Home » Audio » Radio » philco model 111 (reception fades out)
Re: philco model 111 [message #62346 is a reply to message #62344] Tue, 13 April 2010 21:13 Go to previous messageGo to previous message
Have you replaced all the other capacitors? Are there any electrolytic or paper capacitors? Mica and ceramic capacitors are reliable, you're right, but electrolytic and paper caps are extremely unreliable and almost every old radio has them.
Also note that molded paper capacitors can look like dominoes just like some mica caps do. If a capacitor is specifically labeled "mica" then I'd be comfortable with it but if it looks like a domino, I wouldn't be.
Previous Topic: Montgomery Ward Airline parts?
Next Topic: Any advice on long wire antenna
Current Time: Wed Oct 28 01:25:08 CDT 2026
