Home » Sponsored » Pi Speakers » 4 Pi Design Questions
Re: 4 Pi Design Questions [message #62252 is a reply to message #62249] Fri, 02 April 2010 20:58 Go to previous messageGo to previous message
Thanks for the compliment. The build is going pretty easy so far except for routing the recessed area for the horn driver. It was a little tricky but I think I am just rusty with my speaker building.
I noticed on your website that you can upgrade to the Jantzen Z-capacitors but you don't specify if they are the Standard, Superior, Silver, or Silver Gold type. Which ones do you provide?
Also, Jantzen doesn't appear to offer 20uF capacitors according to their cut sheet: http://www.jantzen-audio.com/download/Z-caps%20series%20list.pdf
Are you substituting a Dayton Audio capacitor for this one?
Previous Topic: 2Pi's completed - now I want a center channel
Next Topic: 4Pi Plans for new HT build
Current Time: Thu Nov 05 17:08:05 CST 2026
