Home » Audio » Source » Sony TC-650
Sony TC-650 [message #14012] Sun, 08 June 2008 21:00 Go to next message
Leonard Malak is currently offline  Leonard Malak
Where can I obtain an operator's manual for the Sony Model TC-650 reel to reel tape recorder? Or does any one know what the function of the "tape lift" switch on/off is?
Re: Sony TC-650 [message #14014 is a reply to message #14012] Wed, 11 June 2008 18:09 Go to previous messageGo to next message
Have you checked StereoManuals.com?
Re: Sony TC-650 [message #14015 is a reply to message #14014] Wed, 11 June 2008 18:39 Go to previous messageGo to next message
I sent for a service manual from Vintage Texas, if I ever get it. I was wondering if there is an operators manual for it. I bought the tape recorder used, as is. It works fine, but I don't know what the tape lift function does. Thanks for the info anyway.
Len
Re: Sony TC-650 [message #14016 is a reply to message #14015] Thu, 12 June 2008 08:41 Go to previous messageGo to next message
slbender is currently offline  slbender
Usually such a switch function that affects the tape lifters on other sets is commonly called a "search" function. The tape lifters pull the tape away from the heads during fast functions such as: fast forward, rewind and pause, to prevent head wear.
A tape lifter disable is really only useful either when editing or moving the tape by hand to hear what is on the tape at a precise point; or to hear tape output during fast wind or rewind to get to a point where the program, song, or selection ends.
Hopefully Sony's implementation of the tape lifter disable switch also reduces the audio level by 10 dB or 20 dB to make sure its use doesn't inadvertently blow out the tweeters and/or woofers in your system, by applying supersonic or subsonic audio quite when at high wind speeds - at normally high audio levels... YMMV..
-Steven L. Bender
Re: Sony TC-650 [message #14017 is a reply to message #14014] Thu, 12 June 2008 11:44 Go to previous messageGo to next message
Thanks for the info. It makes sense. Saves on the ware of the heads during wind and rewind and frequent cleaning due to tape residue. I usually just used the counter for editing, but this would be more precise. This is the first recorder I've seen it on, that's why I didn't know what it was for. I really appreciate your response.
Thanks again.
Len
Re: Sony TC-650 [message #14023 is a reply to message #14014] Thu, 21 August 2008 19:32 Go to previous messageGo to next message
Got the repair manual from Stereo Manuals, thanks, but am still looking for the operator's manual for the same. Anyone??
Re: Sony TC-650 [message #14027 is a reply to message #14023] Mon, 29 September 2008 16:35 Go to previous messageGo to next message
Don't they have operators manuals there too?
Re: Sony TC-650 [message #14029 is a reply to message #14027] Tue, 30 September 2008 12:34 Go to previous messageGo to next message
No they don't. I have two service manuals now, one from Stereo Manuals & another from Vintage Texas. Neither place has the operator's manual. I would like to know how to do certain recordings (ex: sound on sound, sound with sound etc) since I bought the recorder used "as is", it didn't have the operator's manual. The recorder work's great. I have serched the internet to no avail to see if any one has the recorder for a copy or an original. Any other other ideas? Would greatly appreciate it. Thanks!
Len
Re: Sony TC-650 [message #60496 is a reply to message #14029] Thu, 30 July 2009 09:31 Go to previous messageGo to next message
AV-CARL is currently offline  AV-CARL
I have a TC-650 Owner's Instruction Manual I would be willing to copy it for you and email it to you (PDF) for a copy of the service manual.
Re: Sony TC-650 [message #62160 is a reply to message #60496] Tue, 23 March 2010 13:46 Go to previous messageGo to previous message
kelpugh is currently offline  kelpugh
Hello my name is Kathy and I would like a pdf manuel of the sony tc-650 my email is wealthykelly@yahoo.com
Previous Topic: What are these controls? (Quanta 450sx)
Next Topic: Is There A Way To...
Current Time: Sun Oct 25 08:23:39 CDT 2026
