Home » Sponsored » Pi Speakers » 4 Pi speaker stands?
Re: 4 Pi speaker stands? [message #62089 is a reply to message #62083] Sun, 14 March 2010 22:56 Go to previous messageGo to previous message
I generally suggest stands if subs are used, and no stands if subs aren't used. You can use angled risers instead.
Baffle step is actually a directivity issue, and all my larger speakers employ controlled directivity. The cornerhorns use the corner to help set the pattern, and while others don't, the baffle is large enough to create some directivity down into the modal region, where directivity begins to lose its meaning. That's where the multisub configuration will help.
Previous Topic: 7PI midrange horn box volume
Next Topic: 1pi plans
Current Time: Sat Nov 28 18:54:54 CST 2026
