Home » Sponsored » Pi Speakers » 6pi Plans
6pi Plans [message #61890] Wed, 17 February 2010 09:44 Go to next message
Justin Morken is currently offline  Justin Morken
I'd like to have a look at the 6pi plans to compare them to the 7pi's I'm considering.
Thanks Wayne!~
Re: 6pi Plans [message #61892 is a reply to message #61890] Wed, 17 February 2010 10:20 Go to previous messageGo to next message
You've got mail!
Re: 6pi Plans [message #61896 is a reply to message #61892] Wed, 17 February 2010 14:01 Go to previous messageGo to next message
Hmmm...
It didn't show up. I've gotten your e-mails before. Maybe the attachment is too big?
try sending it to justin(dot)morken(at)hbsound(dot)com
Thanks!
Re: 6pi Plans [message #61898 is a reply to message #61896] Wed, 17 February 2010 19:17 Go to previous messageGo to next message
No, probably not. I'm at a customer site in Kansas City this week, so maybe the internet is kinda wonky here. Anyway, I've resent, so check your mail now. Should be at both addresses.
Re: 6pi Plans [message #61899 is a reply to message #61890] Wed, 17 February 2010 22:32 Go to previous messageGo to next message
Got it!
So, after looking at both the 6 and 7 Pi plans, I'm trying to understand the tradeoffs. If you don't mind, I'd just like to make sure I got it right:
-both the 6 and 7 Pi have an identical crossover
-the 6 Pi cabinet is larger (2.75cu.ft tuned to 31hz)
-the 7 Pi cabinet is smaller (2.35cu.ft tuned to 39hz)
-the 6 Pi has more bass gain and extension than the 7 Pi
-the 6 Pi has less maximum output (112db should be plenty Very Happy )
If the above is true, I think the 6Pi may work better in my room. It is the main living area - 19'x34' with large openings to the rest of the house and a partially vaulted ceiling. The system will be used for music and movies, and I am hoping to watch movies without needing a sub. I might be asking alot of two 12's, but it seems the 15's won't go deep enough without a much larger enclosure. Does this all sound kosher?
Re: 6pi Plans [message #61900 is a reply to message #61899] Wed, 17 February 2010 22:51 Go to previous message
All that's right, you sized 'em up. I'd like to add that both cabinets are aligned slightly overdamped. This gives a slow gradual response curve, and both are pretty similar really.
Previous Topic: pi 1 and pi 8 plans
Next Topic: 4pi design plans
Current Time: Wed Nov 04 17:23:42 CST 2026
