Home » Audio » Speaker » Optimum range JBL 2226
Re: JBL 2226 Usage [message #61790 is a reply to message #61789] Fri, 29 January 2010 18:29 Go to previous messageGo to previous message
I agree with you on limiting cone excursion on mids and low xmax drivers using a high-pass filter, and wouldn't have suggested removing the high-pass if you were running any real power to the drivers.
What we have is competing priorities: Increasing the number of sound sources in the modal region is a good thing because it smoothes that range. This is why there is an advantage running the mids/mains all the way down as low as they'll go. But then there's the IMD/excursion issue, and you definitely don't want to push the driver close to xmax. If you need higher SPL, then it makes sense to high-pass the mids/mains because they'll likely see some power. To me, the balance is struck where power requirements don't exceed xmax at the lower limit of the mid/main passband.
Previous Topic: Can anyone help me find this line array elemnts.
Next Topic: Klipsch
Current Time: Sat Aug 15 15:11:09 CDT 2026
