Home » Audio » Source » Pioneer RT-909 (Speed Problem 7.5 Only)
Pioneer RT-909 [message #61691] Fri, 08 January 2010 13:25 Go to next message
timestar is currently offline  timestar
I have a RT-909 with a 7.5 speed problem - way too slow...3.75 is fine, but 7.5 almost runs the same as 3.75. Help anyone? Very Happy
Re: Pioneer RT-909 [message #61693 is a reply to message #61691] Fri, 08 January 2010 13:36 Go to previous messageGo to next message
Mine did that too. It was a two-fold problem for me: The pinch roller was gummy and needed to be replaced. Check that - it's pretty common - If the roller feels tacky to the touch, it must be replaced. However, mine also needed an adjustment. I was lucky though - I'm told that the motors are fairly common failure modes and I'm not sure you can get those anymore. Do a search here for "Pioneer" because there are lots of posts about this unit.
Re: Pioneer RT-909 [message #61694 is a reply to message #61693] Fri, 08 January 2010 13:59 Go to previous messageGo to next message
Thanks, Wayne. I'll check the pinch rollers, but I think they are new. What kind of adjustment did yours need? I'm told by local repair that it is probably a problem on the DC board at a cost of $250.
Robert
Re: Pioneer RT-909 [message #61695 is a reply to message #61694] Fri, 08 January 2010 14:11 Go to previous messageGo to next message
Mine was a "speed adjustment", but since they're DC motors, it may be the same thing your shop is talking about.
Re: Pioneer RT-909 [message #61696 is a reply to message #61695] Fri, 08 January 2010 15:01 Go to previous messageGo to next message
It was the belt...I just put a new one on. Laughing Very Happy Very Happy
Re: Pioneer RT-909 [message #61697 is a reply to message #61696] Fri, 08 January 2010 16:25 Go to previous messageGo to next message
Awesome! That's a simple fix!
Re: Pioneer RT-909 [message #61698 is a reply to message #61697] Fri, 08 January 2010 18:18 Go to previous messageGo to next message
Thanks for answering and trying to help me!! Smile
Re: Pioneer RT-909 [message #61902 is a reply to message #61696] Thu, 18 February 2010 13:27 Go to previous message
AudioAJ is currently offline  AudioAJ
timestar wrote on Fri, 08 January 2010 15:01
For me, whenever I've had problems with speed issues, that's usually the first place I check. Go with the easiest and cheapest fixes first.
Previous Topic: CROSLEY KEEPSAKE TURNTABLE STOPPED SPINNING
Next Topic: Fried my SL1200
Current Time: Fri Nov 27 13:34:00 CST 2026
