| Re: 4 Pi and 7 Pi bass response- More similar or different? [message #61622 is a reply to message #61576] |
Mon, 28 December 2009 13:00   |
tom-m
Messages: 56 Registered: December 2009 Location: Texas
Baron |
Hi Wayne,
I did a rough build of a midhorn, to get a perspective on its size, and to see if I ran into any problems. I just made it with butt joints, using 0.75 in plywood. The butt joints don't meet flat, I guess because of the flare of the horn. I used the dimensions from the link I posted a few replies up. Does the full 7pi plans have more detailed construction of the midhorns? If so, I may need them.
Also, I will probably buy 7pi crossovers from you, but wanted to know what is the crossover point between the woofer and midhorn?
Here are 2 pics of my rough build midhorn.
Thanks,
Tom
Attachment: horn01.jpg
(Size: 51.73KB, Downloaded 8038 times)
Attachment: horn02.jpg
(Size: 57.48KB, Downloaded 7918 times)
