Home » Sponsored » Pi Speakers » 3Pi Satellite idea (small(ish) sealed 3pi with sub)
Re: 3Pi Satellite idea [message #61492 is a reply to message #61424] Tue, 01 December 2009 17:05 Go to previous messageGo to previous message
Justin Morken is currently offline  Justin Morken
I guess I hadn't even considered bracing and baffle strength Rolling Eyes
I just looked at the blank wood between the woofer and tweeter and thought to myself "hey, they aren't touching yet!"
I'm doing my darndest to preserve as much of your design work as possible while trying to reach a better WAF. I think I may have mostly given up. I'm now considering building the plans as drawn, but adjusting the dimensions taller, narrower, and deeper so as to have a "tower" speaker. 34"H x 14"W x 16.5"D will give me almost identical volume and has well spaced resonances. I tested the original box dimensions against my new dimensions with Boxnotes and the resonances seem to be pretty comparable. The only factor I can't calculate is port placement in relation to box nodes (something you've already figured out).
You're video was very helpful. Seeing the vertical nulls spaced that far apart is pretty impressive.
Previous Topic: 4 pi plans
Next Topic: Horn angle !!!
Current Time: Thu Nov 05 20:01:34 CST 2026
