Home » Sponsored » Pi Speakers » 3Pi Satellite idea (small(ish) sealed 3pi with sub)
3Pi Satellite idea [message #61424] Fri, 20 November 2009 12:38 Go to next message
Justin Morken is currently offline  Justin Morken
I'm thinking about building a set of 3Pi speakers into 1.5cu.ft sealed boxes to use for HT and music. The Delta-12LFA models very well sealed, giving an almost ideal 2nd-order roll off @ 80hz (THX standard). They will be stand mounted (horn center @ 34") and placed directly against a wall. The baffles will be 14" wide. I'm wondering if there are any glaring problems with this idea. I understand there is no baffle-step compensation in the crossover and I the speakers should be close enough to quarter-space to make it unnecessary (I think?).
The logic for this is to achieve an acceptable WAF while retaining most of the advantages of a large two-way (I just love good horn systems!). I attached the WinISD sim (shown with subwooder and THX crossover in place) and a Sketchup image of my concept. I'd appreciate any feedback you might have!
Thanks!
Re: 3Pi Satellite idea [message #61429 is a reply to message #61424] Fri, 20 November 2009 15:58 Go to previous messageGo to next message
I understand your desire to make the cabinets smaller. That's a worthy goal. And I think what you've described is probably pretty safe. However, I want to mention that you're not looking for crossover between subs and mains when used indoors, at least not in the traditonal sense. What you want is overlap, in this case, because you want multiple sound sources in the modal range.
One of the most important things for getting smooth, uniform bass indoors is having multiple sound sources below ~100Hz, positioned at different places in the room. For best sound quality, you really don't want to have just one sub covering this range.
Re: 3Pi Satellite idea [message #61432 is a reply to message #61424] Fri, 20 November 2009 18:00 Go to previous messageGo to next message
Thanks for your feedback!
I've heard of the Multisub concept before, and I guess I need to break old HT habits. I think I can find a way (with my receiver) to let the tops run full range. This will at least give me -6db @ 60hz. I know I can't have my cake and eat it too (great bass AND small enclosures) so this is one of the compromises I'll have to make. I could EQ a little more extension in - at the expense of headroom.
I'll post updates as I make progress on the project.
Re: 3Pi Satellite idea [message #61468 is a reply to message #61424] Wed, 25 November 2009 09:21 Go to previous messageGo to next message
Great Idea, just needs more subs. There has to be a way around this.
Re: 3Pi Satellite idea [message #61470 is a reply to message #61424] Wed, 25 November 2009 12:07 Go to previous messageGo to next message
Wayne,
I know you've put a lot of consideration into the driver spacing and placement in your designs. What are the trade-offs when moving the horn and woofer closer together? In a typical design this is almost always a "good thing" but I've heard you mention that you've used the driver spacing to steer the response lobes.
Re: 3Pi Satellite idea [message #61472 is a reply to message #61470] Wed, 25 November 2009 15:31 Go to previous messageGo to next message
In general, closer spacing is a good idea. But the drivers are fairly close - you can't really get them any closer on the four π and while you could on the three π, certainly not by much. They're pretty closely spaced as designed. Just enough room between them to get a brace in there. Closer than that and there's not enough meat to retain strength and allow room for an internal brace, which is pretty important.
I tested with the configuration as shown in the plans, and I would probably be hesitant to deviate. The nulls are widely spaced and the forward lobe is well formed. Best not to mess with success, in my opinion.
Look how far apart the nulls are in the video contained in the link below. Also notice how smooth the response is through the arc between nulls. It's a very nice, smooth pattern. I wouldn't modify the layout unless you had measurement equipment and time to optimize. I mean you can, and I wouldn't expect adverse results from inching the tweeter closer to the woofer a smidge, but you wouldn't know unless you measured to see. And again, you need room to put the cross brace, so I'm not sure it's worth spending a lot of time to investigate.
Re: 3Pi Satellite idea [message #61492 is a reply to message #61424] Tue, 01 December 2009 17:05 Go to previous messageGo to next message
I guess I hadn't even considered bracing and baffle strength Rolling Eyes
I just looked at the blank wood between the woofer and tweeter and thought to myself "hey, they aren't touching yet!"
I'm doing my darndest to preserve as much of your design work as possible while trying to reach a better WAF. I think I may have mostly given up. I'm now considering building the plans as drawn, but adjusting the dimensions taller, narrower, and deeper so as to have a "tower" speaker. 34"H x 14"W x 16.5"D will give me almost identical volume and has well spaced resonances. I tested the original box dimensions against my new dimensions with Boxnotes and the resonances seem to be pretty comparable. The only factor I can't calculate is port placement in relation to box nodes (something you've already figured out).
You're video was very helpful. Seeing the vertical nulls spaced that far apart is pretty impressive.
Re: 3Pi Satellite idea [message #61494 is a reply to message #61492] Tue, 01 December 2009 19:08 Go to previous message
Grab a copy of Martin King's spreadsheets. That will help you determine where to put the woofer and port in a tower cabinet enclosure.
Previous Topic: 4 pi plans
Next Topic: Horn angle !!!
Current Time: Thu Nov 05 19:44:56 CST 2026
