Home » Sponsored » Pi Speakers » 3Pi Satellite idea (small(ish) sealed 3pi with sub)
3Pi Satellite idea [message #61424] Fri, 20 November 2009 12:38 Go to previous message
Justin Morken is currently offline  Justin Morken
I'm thinking about building a set of 3Pi speakers into 1.5cu.ft sealed boxes to use for HT and music. The Delta-12LFA models very well sealed, giving an almost ideal 2nd-order roll off @ 80hz (THX standard). They will be stand mounted (horn center @ 34") and placed directly against a wall. The baffles will be 14" wide. I'm wondering if there are any glaring problems with this idea. I understand there is no baffle-step compensation in the crossover and I the speakers should be close enough to quarter-space to make it unnecessary (I think?).
The logic for this is to achieve an acceptable WAF while retaining most of the advantages of a large two-way (I just love good horn systems!). I attached the WinISD sim (shown with subwooder and THX crossover in place) and a Sketchup image of my concept. I'd appreciate any feedback you might have!
Thanks!
Previous Topic: 4 pi plans
Next Topic: Horn angle !!!
Current Time: Thu Nov 05 19:45:20 CST 2026
