| 3Pi Satellite idea [message #61424] |
Fri, 20 November 2009 12:38  |
Justin Morken
Messages: 12 Registered: May 2009
Chancellor |
I'm thinking about building a set of 3Pi speakers into 1.5cu.ft sealed boxes to use for HT and music. The Delta-12LFA models very well sealed, giving an almost ideal 2nd-order roll off @ 80hz (THX standard). They will be stand mounted (horn center @ 34") and placed directly against a wall. The baffles will be 14" wide. I'm wondering if there are any glaring problems with this idea. I understand there is no baffle-step compensation in the crossover and I the speakers should be close enough to quarter-space to make it unnecessary (I think?).
The logic for this is to achieve an acceptable WAF while retaining most of the advantages of a large two-way (I just love good horn systems!). I attached the WinISD sim (shown with subwooder and THX crossover in place) and a Sketchup image of my concept. I'd appreciate any feedback you might have!
Thanks!
| Re: 3Pi Satellite idea [message #61472 is a reply to message #61470] |
Wed, 25 November 2009 15:31   |
In general, closer spacing is a good idea. But the drivers are fairly close - you can't really get them any closer on the four π and while you could on the three π, certainly not by much. They're pretty closely spaced as designed. Just enough room between them to get a brace in there. Closer than that and there's not enough meat to retain strength and allow room for an internal brace, which is pretty important.
I tested with the configuration as shown in the plans, and I would probably be hesitant to deviate. The nulls are widely spaced and the forward lobe is well formed. Best not to mess with success, in my opinion.
Look how far apart the nulls are in the video contained in the link below. Also notice how smooth the response is through the arc between nulls. It's a very nice, smooth pattern. I wouldn't modify the layout unless you had measurement equipment and time to optimize. I mean you can, and I wouldn't expect adverse results from inching the tweeter closer to the woofer a smidge, but you wouldn't know unless you measured to see. And again, you need room to put the cross brace, so I'm not sure it's worth spending a lot of time to investigate.
