Home » Audio » Speaker » 12inch full range driver in tl enclosure
Re: 12inch full range driver in tl enclosure [message #61390 is a reply to message #22076] Tue, 17 November 2009 03:31 Go to previous message
Back in the day I built more bad transmission lines than you could shake a high-end cable at. Then I discovered one of the secrets: start with a high Qts driver, like between .50 and .80. So if I was going to do a high efficiency transmission line system, I'd probably start with one of the PHY drivers or something similar.
Previous Topic: enclosure uni project, and ideas?
Next Topic: Choosing Tweeters
Current Time: Mon Nov 02 04:22:04 CST 2026
