Home » Audio » Speaker » First speakers - a little ambitious - curved array
Re: First speakers - a little ambitious - curved array [message #61261 is a reply to message #61257] Thu, 22 October 2009 16:53 Go to previous messageGo to previous message
Marlboro
If your c-to-c on the mids is only 2.17 then they will not comb filter at 5000, and the ribbons don't have that kind of problem.
Looks good then.... to me! Don't worry about comments from people who make cryptic statements and don't tell you why.
How low do those little fellows go for a two way? They look sort of like a 2 inch mid range dome. PE makes one of those and they don't go lower than about 400hz
I don't think that the distance between the two portions of the mid range array are an issue but is there wa reason why you didn't make the baffle wider and put the tweeter on the side?
Marlboro
Previous Topic: Multiple Subwoofers
Next Topic: Open Baffle or none at all?
Current Time: Sun Nov 22 06:27:32 CST 2026
