Home » Sponsored » Pi Speakers » 2-Pi tower box !!! (box usage)
2-Pi tower box !!! [message #61254] Thu, 22 October 2009 09:34 Go to next message
Can the 2-pi tower be used for the 3-Pi 12 inch woofer and horn ?
What would be the spacing ? THanks
Re: 2-Pi tower box !!! [message #61260 is a reply to message #61254] Thu, 22 October 2009 16:23 Go to previous messageGo to next message
I've never put that woofer in a cabinet like that. I suppose it would work, probably with some port retuning. I'd keep the woofer to tweeter distance relationship the same.
Re: 2-Pi tower box !!! [message #61270 is a reply to message #61260] Mon, 26 October 2009 09:44 Go to previous messageGo to next message
cookietruck is currently offline  cookietruck
i built a 3pi in a little taller enclosure than the plans spec'd.
i'm happy with the sound...still haven't unhooked them to stain and finish...
i haven't heard the regular 3pi so i can't comment on sound differences.
also my enclosures are still only 34" tall. i think the 2pi tower is much taller than that right?
Re: 2-Pi tower box !!! [message #61273 is a reply to message #61254] Mon, 26 October 2009 14:16 Go to previous message
I believe the 2-pi towers are 46 inches tall x 16 inches wide x 13 inches deep.
Previous Topic: Multible subs.
Next Topic: 4PI
Current Time: Fri Nov 06 23:13:17 CST 2026
