Home » Audio » Speaker » Finally Building Full Range Single Driver Speakers
Re: Finally Building Full Range Single Driver Speakers [message #61139 is a reply to message #60822] Wed, 07 October 2009 07:11 Go to previous messageGo to previous message
Skip Pack wrote on Thu, 10 September 2009 14:35
You can pull all those amps out of the closet if you
use a line level BSC filter ahead of the amp...
Skip
This is a one month delayed response, but you make a good point! I once tried a Behringer DEQ2496, which worked great for equalization, but it diminished the soundstage. I've been considering a dbx DriveRack PA+. I was told it sounds better than the less expensive Behringer products, but at $500 it would cost more than the speakers. The upside is that it's also an electronic crossover, which I could use with two-way speakers.
I've finally gotten around to cutting some mdf panels, so the project is now underway.
Previous Topic: MTM horizontal arrays
Next Topic: Dipole/Bipole Transmission Line
Current Time: Sun Nov 15 23:07:48 CST 2026
