Home » Audio » Speaker » Line arrays: 3 way(4 way) or two way
Re: Line arrays: 3 way(4 way) or two way [message #61083 is a reply to message #61075] Mon, 28 September 2009 22:50 Go to previous message
darkmoebius2 is currently offline  darkmoebius2
selahaudio wrote on Mon, 28 September 2009 18:05
Well if you don't want a crossover point in the 1-2.5K range then you probably should consider another type of design.
Sorry, I guess, in my long-winded story, I forgot to make the point that the ESP's showed me it was possible to have that fullrange single-driver type of coherence in a multi-way system - even without SET amps.
Is it possible the 1st order crossovers play a bigger part in the sensation of coherence than the actual crossover points?
In reality, it is probably the whole enchilada - drivers selection, crossover points & slope, cabinet, and complete speaker design. But, I'd sure like to know if anyone has noticed whether 1st order x-o's sound significantly different than others when well executed.
Marlboro wrote on Mon, 28 September 2009 18:58
So I take it that you don't have a line array?
Nope, not yet. I'm still in the heavy research phase. I only make major system changes once every 5-7 years, that includes 1-3 years of research, hemming and hawing, and false starts.
So, I still have a long way to go in the learning department since this will require totally different amps(bi or tri). Since my current system is all single-ended, I'd like to go fully balanced/differential from end to end.
I hope to get out and hear a few commercial designs in the next month or so. It turns out that Audience is HQ'd about 2 hours away from me in San Diego, so that might worth the drive. And there is a pair of Tonian Pipedreams (improved Pipes) for sale about an hour from me.
Previous Topic: New sale price on a Vifa 3.5 incher
Next Topic: Symmetrical and asymmetrical slopes in crossovers
Current Time: Fri Sep 25 21:15:56 CDT 2026
