Home » Audio » Speaker » Crossover Question about building line arrays
Re: Crossover Question about building line arrays [message #60992 is a reply to message #60991] Wed, 23 September 2009 15:04 Go to previous messageGo to previous message
selahaudio is currently offline  selahaudio
jp wrote on Wed, 23 September 2009 13:51
Hello Rick
You say :""There are some options. DBX has a DSP crossover (DriveRack PA+)for $500. Built better than the Behringer and also has parametric EQ for baffle step and response contouring. I also have access to a 3-way DSP crossover that includes ICE amps. It's more expensive, but for $2,000 you have six amp channels and a DSP crossover""
Is the difference between Behringer and DBX worth the change ?
Tell us more about this 2000 $ 3 way DSP Crossover, it seems to be in between the DBX and DEQX , where to get it from and what's the make and model ?
Thanks
JP
I've not compared the DBX and Behringer side-by-side but an earlier version of the DBX that I heard worked well for my customer. You probably could find some opinions on a pro audio site because that's where the two are primarily used.
The unit I mentioned is only available to OEM's as far as I know. There may be something available from Hypex that's similar but I don't know if it's in production yet.
Previous Topic: Bose Line Array
Next Topic: Widerange midwoofers, specs, and x-o pts...
Current Time: Fri Oct 16 19:27:39 CDT 2026
