Home » Audio » Speaker » Tweeter Options for Line Arrays
Tweeter Options for Line Arrays [message #60969] Mon, 21 September 2009 19:52 Go to previous message
Rick, I noticed you've designed line arrays using Fountek ribbons, BG Neo 8's, and Dayton PT2's. Each seems to have its own set of advantages and disadvangages:
Zaph's distortion results have convinced many people that the Fountek NeoCd2 isn't a viable choice. However, reviewers almost universally rave about their sound, and they seem to be the only choice for a speaker whose woofer array will be more sensitive than 95dB. Also, they can be used with a 6.5" woofer array, which negates the need for a subwoofer.
The Neo 8's relatively low sensitivity, limited dispersion, and lack of upper octave output seem to be a great disadvantage, but they can be crossed very low, and every year when I hear them in line arrays at RMAF they sound very impressive.
The PT2 is the least expensive, and if it's really a Silver Flute YAG-20 with the Dayton brand on it, its distotion tests aren't good. However, when I heard them in a line array they sounded about as good as a comparably priced dome, and they are the only ribbon/planar tweeter choice for an array that can be built for under $1.5K.
So there's lots of confusion about these tweeters out there. Since you're the only person I know who has actually heard them in a line array application I was wondering how you would compare their sound in your designs.
Previous Topic: Why would I not?
Next Topic: Bose Line Array
Current Time: Sun Nov 22 22:41:15 CST 2026
