Home » Audio » Speaker » Help with Potential Line Array Project
Re: Help with Potential Line Array Project [message #60837 is a reply to message #60834] Fri, 11 September 2009 17:06 Go to previous messageGo to previous message
mayhem13 is currently offline  mayhem13
Thanx for the Reply Marlboro and yes...i followed your link to the white paper and read it again...did so a few months ago when i first considered the idea.
I'd like to use the SB Acoustics SB29 as i have em already. With the faceplate removed the C to C spacing to the first two woofers would be 3.65 inches. I just haven't done the math on efficiency of the woofer line to see if the sensitivity will match up. Didn't want to waste the time if the overall idea was flawed beyond repair.
AS to the SB29, i'm doing some extensive waveguide testing with a group now and one option is rear mounted with a 1" deep DIY waveguide/horn load cut into the baffle but i'm not sure the added directivity would be a plus in an array arrangement.
Previous Topic: Play it again Sam: Share about your line array!
Next Topic: Fitting line arrays together
Current Time: Fri Sep 25 01:04:50 CDT 2026
